pencilgeek
Industrial
- Nov 11, 2010
- 36
Is anyone else having problems with included arcs in a sketch not updating related geometry? Not having any issues with included points or lines. When the original arc (part of another sketch) is changed, the included arc changes per the original, but any relations to that included arc do not.
For example, I have an arc in a newer sketch that is coincident and equal (or concentric and equal radius in the old sketcher) to an included curve that was created from an arc in an older sketch. I then edit the older sketch and move the arc any distance in any direction. When I exit the sketch, the newer sketch has not updated per the previous move. Here's the really weird part, the actual included arc moves to the new location, but the geometric relations don't update. I have tried both non persistent and persistent relations and I get the same behavior.
Running 1973
Chuck
Edit:
I added a screen dump with some notes to help explain the problem. There are two point on curve relations that fail to update and causes the sketch to throw an error and says that the sketch is no longer fully defined. I really hope that we are just doing something wrong and we can just change our mindset on how we sketch. But if it is a problem with the sketcher, then it is a real problem because it does not give you any warnings that your part geometry is not what it is supposed to be.
Running 1973
Chuck
Edit:
