I have been trying to mirror a set of Extruded Cuts about a plane that is 45 degrees to those cuts. When I select the 45 degree plane and the Extruded Cuts as the features to pattern I get one of two messages both resulting in the mirror's failure.
With the "With Geometry Pattern" and "Propagate Visual Properties" checkboxes (located within the Mirror dialog box) both checked I receive the following message:
Rebuild Errors
The selected features could not be patterned using a geometry pattern. Deselect the Geometry pattern check box.
With the "With Geometry Pattern" unchecked and "Propagate Visual Properties" checked or with both unchecked, I receive the following message:
Rebuild Errors
The specified plane should not be perpendicular to the sketch plane.
This really doesn't make to sense to me because as I initially stated, the plane about which I am trying to mirror is at 45 degrees to the entities being mirrored.
Has anyone seen this before? What could be the cause? Interestingly, I have managed to get this type of mirror to work in the past with no such problems.
Rebuild Errors
Rebuild Errors
