jorge0894
Materials
- Jun 23, 2020
- 7
I'm facing troubles when I try to run simulations in Explicit in parallel. The simulation doesn't achieve to start giving the following error:
"Abaqus Error: The executable explicit_dp.exe aborted with system error code 3"
You can find attached a screenshot from the commands prompt with the information about the error when the simulation crashes. There is no any error data in the .dat, .msg and .sta files. I couldn't find any information regarding this kind of error, so I would be so grateful if some of you have the answer to this problem.
Thank you!
Jorge R.
Thank you!
Jorge R.
