I have two generators 1,5 mw on a vessel, and they´re are used to supply the generation plant for the vessel and two syncronous motor used for propulsion, the level on harmonics on voltage is not to big, ok, the problem is that with more than 50% of the load, the signal that comes from pt100 are getting a lot of noise and peak that makes the monitoring system to give a signal of error, i have connected other pt100 on the connections on the generator, and the measure is right... this make me think that i have some problem with the pt100 onto generator slot... but this problem occurs to all the pt100 and in both generators, maybe somebody could helps me in order to know why this is going on. thanks
