german9011
I'm new with ansys if I can help it would be helpful.
the problem is that two solids are shocked, but one of them is going through the other, have already implemented several things different tutorials but the answer is the same. the only question when I change the location fixed support the results change. I've also tried putting speed and standard earth gravity but I do not lack anything the result.
