I am having problems getting ABAQUS Standard 6.2 to solve an indentation simulation. The description of my model are as follows:
-Axisymmetric modelling of soft tissue indentation (rigid indentor indenting a rectangular block)
-Rigid body for hemispherical ended indentor using a reference node to define
-Tissue material properties are E=0.7 MPa, Poisson's ratio=0.49, linear elastic, CAX4 elements
-Boundary condition are xsymm along axis of symmetry for tissue. Last row of nodes at the bottom of tissue block is not allowed to move. Indentation is simulated by displacement of the reference node. Reference node allowed to move in vertical direction only (no rotation as well)
-multiple step loading. Total 3mm indentation (1mm/step)
Using ABAQUS Standard, I was able to get results for up to step 2, but at the last step (3mm indentation), I exprienced convergence problem. I have looked through the .msg file and it looks like this at the last iteration:
INCREMENT 3 STARTS. ATTEMPT NUMBER 1, TIME INCREMENT 1.000E-06
***ERROR: TIME INCREMENT REQUIRED IS TOO SMALL. ANALYSIS TERMINATED.
Appreciate if anyone can provide any ideas to get around this problem to solve in ABAQUS Standard. I have tried hyperelastic elements and it works. I have also tried adaptive meshing with ABAQUS Explicit, while it works, its computational time is longer (about 45 mins). Is this a case of element locking due to the incompressibility?
