We have a 1991 Berthiez (french) Vertical Turning Lathe (model TVM-100). The vertical ram (Z axis) has a live tooling attachment for milling & drilling. In turning / boring mode, the table can reach 600 RPM. In milling mode, a precision, low speed gearbox servo engages the table for a max of 5 RPM. We are trying to mill a rectangle shape into a surface. There is no Y axis ... only X, Z, and B (table rotation axis). Therefore, to mill a straight line, the B and X axes must be synchronized within the FANUC series 15 parameters to yield a perfect point-to-point straight line. However, no matter what line length or feed rate we program, we are consistently getting what appears to be a slight angle at the center distance of each straight line cut. However, it is possible the "out-of-straight" line is really a very shallow curve. For example, in a 16" travel cut, we are getting about 0.005" "out-of straightness" on what should be a perfectly straight edge. As the low speed table rotates clockwise, the part initially rotates "away" from the tool, and then rotates "into" the tool after passing the midpoint of each straight mill cut. It appears the "bends" in the straight milled edges are at the center distance where the X axis starts to reverse direction to maintain the straight cut. In other words, it appears there is something not working correctly with the synchronization of the table rotation (B axis) in relation to the X axis movement. Hope I explained this correctly. Anyone have any ideas where to start, or what to look for? It looks as if this problem may be a common one for any machine that uses this type of syncro between axes to mill straight cuts ... or any other specified shapes as well. One person has raised the question about whether backlash in either axis could be the culprit. If so, how does the Fanuc program compensate for the backlash (assuming it exists)? We have measured near zero backlash in the table, but we have not measured the X axis. However, we have recently completed many precision acme threaded, mating parts using the high speed turning / boring mode of the table, where it must syncronize with the X andf Z axis ... all with no problems. So we assume there is no backlash problem. Thanks in advance for any help on this issue. BTW, we have tried to get technical help from the factory on past issues, but with very little success. Our 1st attempt using the GE Fanuc technician has not worked. GE has another tech coming soon, but thought we may get some help from this forum too. Thanks again.
