STEVE LIU
- Jun 2, 2017
- 15
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Yes , I mean the blackHi everyone,
I have a question. I’ve noticed that many flat-bottom tanks have black lines after being painted.
I’m curious about how these occur. Are they caused by the welds (Welded joint )? If so, what is the reason?
Do you mean the vertical lines?
I strongly suspect these are where they are drain holes in the roof edge and this is where the water drops down, discolours the tank and allows some moss or organism to
Yes, I was referring to the black vertical lines. it was just painted a little over a month ago, so seeing these evenly spaced black lines makes me curious about where they came from.Do you mean the vertical lines?
I strongly suspect these are where they are drain holes in the roof edge and this is where the water drops down, discolours the tank and allows some moss or organism to grow.
