JeffH35
Chemical
- Jul 9, 2004
- 6
Hi All,
Our plant utilizes an activated carbon bed to filter contaminants and "purify" a stream of hot solution. This solution is then cooled/crystallized, fed through a centrifuge and dried, yielding a high-purity product. We started to see contamination of the product and changed the bed as usual. After we changed the bed, we started seeing a grayish color in the centrifuge effluent and our product has routinely failed inspection due to discoloration. We changed the bed entirely, thinking that the carbon was the problem, but ran into the same problem. Since then, we have been flushing the new bed with hot water to try and alleviate the problem.
It seems that the carbon bed has a lot of ultra-fines in it.
Has anyone experienced similar problems? Can anyone make any suggestions?
Any suggestions are much appreciated.
-Jeff
-Jeff
