francoisgl
Automotive
- Jan 4, 2006
- 4
I'm tring to model a forging process with ABAQUS/Explicit, but I've got a problem with self contact (or maybe surface définition). one surface of the elastic-plastic material is schrivelling up during the simulation and after a certain elapsed time one of my boundary node is moving inside the matérial, making the simulation failing.
I defined my surface like this (I aslo tried without the internal surface, without succes, and my elements are CAX4R):
*Elset, elset=S1, instance=lopin, generate
1, 150, 1
*Elset, elset=S1_int, internal, instance=lopin, generate
1, 150, 1
*Surface, type=ELEMENT, name=S1
S1_int, S1
The contact is defined with:
*Surface Interaction, name=contact
*Friction
0.2
*contact Pair, interaction=contact
S1, S1
Any advice would be very appreciated, thanks in advance!
François.
1, 150, 1
1, 150, 1
S1_int, S1
*Friction
0.2
S1, S1
François.
