Product Constrains Analysis 4
CAD2015
Automotive
Jan 21, 2006
2,058
Catia V5 Sketcher has the Sketch Analysis in order to identify and show the under-constrained/over-constrain (the Diagnostic tool) geometry.
I was wondering if CATProduct has something similar.
I work with many assemblies and some of them have a lot of constrains.
It takes a lot of time to verify if the Product is fully constrain, so finding a way to solve this issue would be extremely beneficial and efficient.
CAD 2015
Thank you Drew and Ferdo!
CAD 2015
Please, have a look at the picture....
How could I find out which components are/are not not fully constrained?
What this picture says?
CAD 2015
If I'm not wrong, the table shows that I have three not constrained components, right?
CAD 2015
Yes that is what the function says...
Also check the Degrees of freedom tab
Eric N.
I'm hoping to learn more about assembly constraint analysis from this thread.
Here's a simple little process I do to check my assembly constraints:
1. use the explode tool to move all the parts out of their constrained position
2. update the assembly to move all the parts back into position
The parts that are still in the exploded position are the parts that are not fully constrained.
drewmumaw,
Yes, it is a fluid container. Units: mm.
CAD 2015
