Proe gives the error out of envirnment space
OMERYOUNOS
17
My proe 2000i gives the error "out of envirnment space".i ve tried by setting the initial environment to 4096.but i still get the error.This started happening after installing solid edge ver 6.0.
You may be running out of disk space check to make shure you have room to run even though you may not be saving files to the same drive that pro is loaded it still checks to see if that drive is full. Also check to see where your trail files are going, nothing eats disk space like tail files especially if you like to spin models.
