proe wf5 - relations in repeat region in bom table
engtipzin
1
Hi there,
I have a bom table in an assembly drawing with 48 items. I suppose to replace item 31 with a new part number, but I like to keep other item numbers the same. After I replaced item 31, it bumped up to item 48 and every other from item 32 shifted 1 down.
Is there any way that I can keep these items from shifting, because that cause me to change the BOM documentation.
Thanks much,
eti
I thought there was a config option
keep_item_numbers yes/no but I'm not
100% certain.
Take a look at this closed thread
which answers your question in a how to format.
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
I know this is a month after the initial question, but I seem to recall that Pro/Creo does the number of parts in the BOM based on order of first appearance in the model tree.
That is true unless you sort the BOM by a field.
I think you need to lock the BOM table, ten delete the old entry and the new one will go in at the top.
Ben Loosli
