Anyone familiar with UFC 4-023-03 (2009), particularly the Alternate Path Method as it applies to Structural Steel framing?
A couple questions:
1. The load combination is listed as (1.2 OR 0.9) * Dead Load. Typically a 0.9 factor is used when you have load acting opposite of dead (wind uplift), but with progressive collapse, its all gravity loads. Still, using a 1.2 factor on such an extreme event seems like too much of a penalty.
2. Do you include the floor diaphragm in the building model? The diaphragm tends to take some in-plane forces while still allowing the frame members to be in flexure. It seems unreasonable to neglect the diaphragm, as the slab will be there in the event of a collapse.
3. Any idea what "Gn" is in Figure 3-13 ?
Thanks in advance,
Pete
A couple questions:
Thanks in advance,
Pete
