Dannbr
- Jan 28, 2014
- 2
Hello all,
I am working on a project and wanted some input on what others thought about motor choices and such. I am building a cart to move boxes weighing over 3000 pounds. It is a battery powered device that will be remote controlled. The motors needed must provide 66 ft-lbs of torque each. In order to up the torque worm drives will be used. In choosing between AC and DC motors, I went with 3- phase AC motors with VSDs over DC motors mainly because the price of DC motors is high. Also DC motors would require 90VDC or 180VDC for 2 HP motor. My main concern is motor type because of the high inertia load. I am currently pricing blower style AC motors. Would these be sufficient or would I need to use something more heavy duty? Also, finding an inverter to go from 12V or 24V to 230VAC are pricey. what do you think about DC vs AC in this case? Any suggestions would be helpful
