DO any of you use web based project document management systems......ones where remote users can log in and view documents?
If so which ones would you recommend or if you don't want to name them then what features do you like?
Alternatively have you use an Intranet based system.
I'd like one which was easy to use and organised documents into Projects - with an index page of projects.
I'd also like a document change contol system too so that the latest documents are available but older issues can also be archived.
It would be nice to have a template area where common template documents could be found but I guess this is just a specialised folder.
Last I'd like a message board per project where discussions could take place.
