Of general interest, when retarding the ignition to prevent detonation, your exhaust temps climb thusly increasing boost, which increases inlet pressure until the wastegate pops. Its a wild circle.
You may have luck playing with air to fuel ratios when at hard boost. I have leaned the fuel mixture from L=1 to L=1.4 at 20 psig boost, reducing exhaust temps to 900 Deg F.
By the way, VERY VERY NICE engine! Liquid injection has not caught on here in the states, primarily due to the injection pressures. 125 psig is about 1/4 the amount seen in a typical liquid injector (propane saturation pressure + engine absorbed heat + added heat from road and radiation) I have seem pressures in excess of 400 psig! Add in one Texas day of 90 Degrees, plus road absorbed heat, and your tank temperature can reach 125 degrees F. That equates to 250 psig tank pressure. Liquid injection works by circulating propane through the injectors to flush the partially vaporized propane and returns it back to the tank. Usually, dual fuel pumps are used, one for maintaining a circulating pressure, the other for purging. We then add about 50 psig above the saturation pressure to keep the propane in liquid phase (you may have seen that name in marketing material).
Its not as simple as you may think. Supplying fuel for 500 bhp is no problem, but keeping it in liquid state is. One glug of vapor at an injector and its 270 times leaner than it was. Toss in that the fuel mapping program must operate at 270 times more precise/shorter pulse width profiles, and may injectors cannot operate that fast with an injector pressure that high.
Franz
