mehrdadkntu
Dears,
I have received an NPSH curve from a cryogenic submerged pump Vendor in which a pump-down curve has been also provided (please refer to attached file for similar curve)
The pump is a propane cryogenic submerged type installed in a column inside the LPG tank and sends out the propane from LPG tank to loading port.
Could you, please let me know what is the purpose of pump-down curve for this pump?
Moreover, some levels have been specified with respect to pump bottom datum which is not clear for me:
1- Min start Level= wetted lower bearing
2- NPSHR level at 3% head drop [it is already clear]
3- Pump-down level at head drop (at rated flow)
4- Minimum pump-down=loss of prime (at minimum flow)
