Properties of Diesel
stanier
2,442
I am seeking the properties of diesel at temperatures ranging from 5-55C.
The properties I need are :-
Vapour pressure kPa
Density kg/m3
Viscosity mPa.s
Bulk Modulus MPa
The properties will probably in in a range as the various distillates around the globe will vary.
Data, reference websites, books etc would all be welcome
stanier,
You may not find the vapor pressure of diesel. In my understanding, there is correlation with distillation curve of diesel. You should consult your process engineer.
