Properties of SA 350 LF5 material 1
bagnamento
Nuclear
Feb 23, 2005
30
0
0
GB
anybody knows a good reference to find physical and mechanical properties of low-alloy steel ASME SA 350 LF5 (1-2% Ni).
I guess they won't differ too much from those of any C-Mn steel.
The mechanical properties may be quite different, depending on the thermomechanical history as well as the test temperature. Nickel steels will have substantially higher fracture toughness, with the ductile-to-brittle transition moving to lower temperatures.
