Sorry in advance for the long-winded question.
I do mostly structural design and this particular question is primarily to do with buildings. Sometimes these are elements detailed on other consultants' drawings with a note stating "See Structural Drawings". Some of them are items that may be a delegated design.
There is an increasing demand in my area for the permitted set of drawings to have nonstructural components and their anchorage/bracing to be designed and detailed. We have always designed the vertical and lateral systems to be able to support these elements, but it now seems to be a grey area for the design and anchorage of the specific item. Some of the items have traditionally (in our area) been a deferred and delegated design. Meaning that they occur after the permit has been approved and they require an engineer's seal.
These items typically include architectural partitions, curtain walls, stairways, guardrails, and handrails. Also the bracing and anchorage for fire sprinklers, conduits, pipes, MEP units, trusses, and other delegated designs. Sometimes they may include separate elevator towers, separate stair towers, etc.
I'm curious if other structural engineering companies specifically exclude the many types of structural design that aren't part of the primary gravity and lateral design in their proposals. It used to be that these were by default not included and it wasn't an issue. Lately, I get the impression that this might not be the case and it has become a larger battle.
