Has any one run tests on head temperature vs coolant temp on plain water vs straight Propylene Glycol coolant?
Someone said they noted higher coolant temp when using PG vs water.
Due to the steam pockets that form in areas of the combustion chamber cooling system using water and PG will continuously wet the metal and not cause these pockets.
If a coolant were receiving more of the combustion chamber heat, would it not show higher temp at the coolant temp sensor?
I would think that it would be necessary to test head temp vs coolant temp using both water and PG to know what was happening.
