Mechaneer16
Hi All
Pressure Relief Valve failure due to internal leakage is a common scenario. However, for external leakage i.e. if the leakage occurs through the external seals of the PSV, could it lead to overpressure? Some cartridge type relief valves are installed with O-rings on the outside diameter. Also, a leak can occur from the inlet flange gasket for flanged PSVs. If the external seals leak, would that cause pressure drop and inlet loss for the relief valve and cause overpressure? My understanding is due to the pressure drop through the leak (depends on leak size etc.), the relief valve would not open until the system pressure is considerably above the set pressure. Could anyone confirm this statement?
Is there any resource/ publication that discusses these scenarios? Thanks for your help.
