PRVAR
Luca97
IT
Hello, I'm trying to use the command PRVAR, I've noticed that the maximum number of variables that I can list vs. time is 6. Is there another way to list variable vs. time, also in a *.txt file? Because I've got a lot more...
If someone is interest I've solved using VGET and *VWRITE, at least in this case I can write 9 variables... Better than nothing. But I think that this is the maximum that someone can get!
VGET is the right thing to do. But if you get all the variables written to the same array parameter (with a column for each variable) you can write the hole array using *MWRITE an an appropriate Fortran file descriptor like (999F20.6).
Alex
