palecactus
hello,
im working on a test station to measure water flow of irrigation parts at 20 psi . problem is that when i start testing parts that put out 14 gph and higher (up to 60gph) i cant get to 20 psi. i have a pressure releif valve in front of the regulator and the small procon series 1 pump has a pressure releif vale too. am i putting out the same amount of water that im putting in on the larger volume parts? would a larger pump be the answer?
any help would be appreciated.
