EngineerRed
A customer asked me to stamp the PSV nameplate at 1000 psig , but set the valve at 1030 psig . The PSV should be stamped UV . Does BPVC VIII allow such practice ? The customer points that the code allows 3% tolerance on set pressure , so he demands setting the valve at upper limit . In our experience we've never seen a valve opening exactly at Set point although we bench set at nameplate Set pressure. In this case if we stamp the nameplate at 1000 psi and set the valve at 1030 psi , doesn't the valve fail at 1031 psi?
