PSV sizing for plate exchanger rupture
cswosu
9
0
0
Does anyone have any input on what size of hole might be expected in a plate exchanger if it should happen to rupture? Not quite as straight-forward as using the tube diameter in a shell and tube rupture case.
Any advice is appreciated.
Thanks.
cswosu,
Is this realistic ? My impression of the failure mode for a plate frame heat exchanger is gasket "blow-out"
Can you ever produce a "through the plate" hole by overpressurizing either side of a PHE ?
Contact APV or any of the other large PHE vendors and ask about the results of their test programs.
My opinion only.....
MJC
