If you look at the enthalpy scale on a sea level psych chart, it appears to go to zero at about 32 deg F and 0% RH...following the line, it also appears to be 0 at 30 deg F and 10% RH. I thought the complete absence of energy only occurs at 0 deg K.
I'm trying to calculate the heating requirements to achieve 88 deg F and 50% RH...this has an enthalpy of about 37 Btu/lb. During winter design conditions, I'd like to plan for 0 deg F and 0% RH.
How much energy is required to heat 0 deg F 0% RH air to 30 deg F 10% RH?
