PT Slab on Grade, Grade Beam Horizontal Joint
barret504
5
Slab is a typical waffle PT slab on grade. Does anyone know about the forces in the grade beams if a horizontal joint is installed? As in pouring the grade beams first with draped cables then the 4" PT slab on top. Leaving 8" at perimeter for slab cable installation. I am concerned about the shear transference.
Yes, using the center-lift moments I'm calculating #5 hairpins at 5" oc.
