DrDrreeeaaa
- Apr 25, 2008
- 266
Hi All
We are designing a distributed control system and we would like to find some way of wiring our PTC thermistors into our field remote I/O panels (utilising B&R X20 I/O).
To clarify when I say 'PTC thermistors' I am referring to a thermally sensitive resistor that is NOT intended to measure temperature. It has an extreme resistance characteristic which is ~ 1500 ohm when cold and ~3600 ohm when hot.
The characteristic becomes very steep when the trip temperature is reached and the resistance becomes very high very fast - indicating the winding(s) are overheated.
Many vendors sell relays which will evaluate the state of the PTC thermistors and produce a relay output which can be wired to a PLC.
However many VFDs include a dedicated input for a PTC thermistor which just utilities a 0-10V analog input with a voltage divider - a resistor is added which is chosen to specify a trip point voltage. See attachment
My question is: is there a reason I can't do the same but with a standard 0-10V PLC analog input? I have never seen this done.
Michael
Michael
