PTC thermistors
OutToLunch
24
Does anyone have a source for surface mount PTC thermistors? Specifically, I am looking for a thermistor that would have a room temperature value in the 10k to 30k range and a 0.4%/*C or higher slope.
The only supplier I found that had PTCs with that high of a resistance was a place called Quality Thermistor (thermistor.com). The prices they quoted were unbelieveable - not only were they not in the ballpark, they weren't in the same state.
thanks in advance.
besides thermistor you can use special temp.sensor IC
or even transistor or diode as sensor.
What is your application? How many/year? What kind of accuracy do you need?
Please read FAQ240-1032
My WEB: <
Quality Thermister is frankly... an embarrasment. Their prices are so far beyond usable I too shake my head.
Have you done a Digikey or Mouser search? Digikey shows 12 pages of PTCs in its search engine(perhaps they're all fuses though).
Keith Cress
Flamin Systems, Inc.-
yes, I've searched through those sources. I'm thinking I will have to find some other route. The problem is it has to be as cheap as possible - customers won't want to implement this if it is too expensive.
The PTC would be used as a direct replacement for a resistor in the analog system loop.
