I've been asked to design a small pumphouse to replace a 45 year old system for a campground and bunkhouse. The existing system works well so I will basically copy it. Except for the pump control (old Heally Ruff). It works well but can't be serviced locally.
The exiting system is split, campground summer only, bunkhouse all year. The bunkhouse pumps are controlled based on pressure. The campground pumps are controlled based on the level in a 2000 gallon holding tank (gravity feed from the tank to the campground). The pressure system is easy but I'm not sure about how to easily control the pumps from floats in the holding tank. We'd like to keep it as simple as possible.
