Hi, I am a graduate-level mechanical engineer.
I am working out a hydraulic power using the equation below:
(Q * P) / (600 * e) = kW
Where, Q: Flow rate (L/min), P: Pressure (bar), e: Pump efficiency
I wonder if the pump efficiency 'e' is the total pump efficiency.
I believe there are a couple of types of pump efficiency, such as mechanical efficiency, volumetric efficiency, total efficiency, etc.
I would appreciate it if I could get your advice on which efficiency shall be used for this equation.
Thank you.
Thank you.
