PKEngineer
Chemical
- Nov 27, 2009
- 25
Could anyone explain possible reason(s) for having more differential head through centrifugal pump than rated (more than shut-in pressure)for liquid butane service pumping from suction sphere. Flow rate is within the operating range as measured?
I would assume suction and discharge pressure gauges are providing the right measurements.
Please ask me more specifics if more explanation required
Thanks/Regards
Thanks/Regards
