sybie99
- Sep 18, 2009
- 150
Hi Guys
I have a case where the contractor would like to use a concrete pump to pour a 4m high wall in one go. The structure is water retaining (as per BS8007, the British Code for water retaining structures). I know that a pump mix is very different to a normal mix, it has a high slump, possibly plastisizers as well. I am no expert in the design of a typical pump mix, but my question is whether there are any problems that could occur when using a pump mix in walls (250mm thick wall). In my experience pumped concrete is generally used to construct slabs, not walls. Seeing that the wall needs to be water retaining, could there be issues with shrinkage cracking or any other potential problems stemming from the use of a pump mix?
Seb
Seb
