Andrew ONeill
Hi Team,
I went down a rabbit hole a little while ago about using instrumentation to prove a centrifugal pump is primed. Intent is to have interlocks or alarms to prevent dry running of said pump after a maintenance changeout and / or suction piping lineup changes. I'll note the question for this topic is about instrumentation, not about changing seal / pump types, piping layout etc.
The specific scenario is shown in the attacked sketch.
I won't go into the issues of why this is being looked at, other than to say it involves competence / knowledge of the people operating the equipment.
1) Traditional (somewhat dodgy) way to prove priming is to use a suction pressure transmitter. If P >0, must have liquid, therefore primed. In practice not true but, does work reasonably well if the reservoir is above the pump, which in this case it isnt.
2) Monitor flow meter, if no flow for XX seconds, trip pump -> This works, but typically results in pump damage bring done during the dry run period. Also the nature the pump system is that it pumps uphill, so the pump will dead head on startup until the speed is sufficient to overcome the existing system discharge head. (so a "no flow trip" needs some amount of time delay to avoid spurious tripping, typically around 30 seconds)
3) A flow switch, same as 2) above
4) led me down that last pathway of a level switch / level transmitter. Install a level switch / transmitter in a suitable location, if level detected, then pump is primed. for me this seems to be to only reliable way to detect pump prime prior to starting the pump.
5) Another idea was to monitor VSD power, if no fluid in the pump, power draw should be very low, might be able to setup a fairly simple equation and trip pump if power is very low vs pump speed. again this if after startup, but conceivable could have a short delay timer of say 5 seconds vs a typical delay of 30 seconds for the flow meter example, which would likely be a tolerable dry run time.
I'm curious if anyone has experience in this sort of arrangement, has any comments, or other ideas along this line.
