Torque100Nm
Good day,
Please I need help on a project. I'm to select a three (3) submersible pumps to move water from a well of 7m to a of stream of about 1000m away from the well. The pumps has of 308GPM with Maximum head of 25.8m each and rated power for the pumps is 4kW each. The discharge size of the pumps is 65mm and suction is also 65mm. The problem I have now is the onsite pipe size which is 200mm HDPE. Will using reducers to connect the pump discharge from 65mm to 200mm to the total horizontal distance of 1000m work? All three (3) pumps will be connected to same discharge header to the stream.
Thank You
Thank You
