Trying to determine proper shaft material for a 2000 HP verticle turbine pump 34 feet long three section shaft used in secondary waste water treatment plant to pump effluent to trickling filters. The suggested material is ANSI 410 tensile 111596 psi yeild 87269 psi and elong. at 25.9. Is this material suitable for this application.
