Pump suction Strainers Pressure Drop
Sawsan311
Chemical
Jun 21, 2019
303
Dear All,
As there are various types of pump suction strainers such as basket, Tee and Y type strainers which vary with respect to the need for automated flushing through blowdown, tolerance for heavy fouling services etc. What is the typical maximum allowable pressure drop which a designer need to account for a Tee strainer in determining the pump's NPSHA at the early design stage. Knowing that Crane considered around 35 D equivalent length for a suction Tee strainer, however when I compared such consideration to actual pump suction strainer vendor's pressure drop as 0.4 barg, I see that if the designer relies on specifying the strainer as a normal fitting without accounting for higher pressure drop contingency, there could be significant difference in the suction pressure calculated.
Therefore, for a typical low emulsion crude application, what should be the pressure drop contingency to be considered for suction Tee type strainer of a pump?
Appreciate your valuable views.
A normal assumption for a strainer pressure drop is about 0.1 bar clean, 0.5 dirty.
That's why suction strainers on systems with low inlet pressure / marginal NPSHA are not normally used.
So it's a bit of a risk about your pump, but better than it destroying itself due to cavitation due to a dirty strainer no one bothers to clean or even check to see if it needs cleaning.
