Well, the axial thrust is the change in momentum of the fluid along the x-axis (with that axis defined as the axis of rotation of the shaft) plus the pressure differential between the back of the impeller and the front of it - corrected for the area of thrust - that being the cross section of the impeller minus any balance holes.
Just do a force calc similar to that of a turbine blade, assume a blade angle (which is not constant, but for quick and dirty, just try). For pressure behind the impeller, assume a few pounds over suction pressure (5 psig is probably sufficient for quick and dirty) or assume its the same as suction pressure (not a bad assumption, really) behind the impeller to be more conservative. Remember, in overhung end suction type pumps, the shaft seal sees a fluid pressure just slightly above suction (it depends on several factors, but this is generally the case).
As far as Murphy rearing his ugly head with split-case pumps, I can point to hundreds and hundreds of such installations where the pumps have standard single anti-friction radial bearings and do not overthrust the motor (which cannot take any thrust for the most part.) Yes, if designed and built incorrectly, you will not have a balanced radial thrust - but then, you get what you pay for.
Now, if you are using sleeve bearings (not recommended with split case pumps for the most part) then yes, you will need a limited end float coupling. Also, if you use a gear coupling, then the coupling itself will transmit axial thrust to the pump and/or motor.
Unfortunately, I don't think you can come up with a good and meaningful thrust value by any "quck and dirty" method. You can come up with something, but then the question arises, what use is that number????
As far as radial thurst, you can use this method:
R = K/Kso * H/Hso * Rso
where:
R = radial force, in pounds, at the operating condition
K = Kso * [ 1- (Q/Qn)^3.3]
Q = operating flowrate, in gpm
Qn = flowrate at BEP
Kso = thrust factor at shutoff head and is equal to:
Specific speed (Nss) Kso
2000 0.34
2200 0.355
2400 0.365
>2400 0.37
Hso = total shutoff head, in feet
H = total oeprating head, in feet
Rso = radial thrust, in pounds, at shutoff
Rso = Kso * Hso / (2.31 * D2 * B2)
where:
D2 = impeller diameter, in inches
B2 = impeller width, in inches, at discharge (including shrouds)
As you see, you need to assume values (or measure them if you have the impeller) of the impeller dimensions. If you want to find deflection since radial thrust in and of itself is a useless value, then use the standard beam equations and use the method of superposition with a stepped shaft. This is compounded if you have wear rings because they act like bearings, so you wind up with a shaft that looks kinda like an S. If you know the clearence of the wear rings, then you can assume them to be rigid motion limiters and use that boundary condition in your analysis. Also, assume anti-friction bearings to be rigid connections.
I hope I haven't muddied the waters too much.
Tim
