EngDM
- Aug 10, 2021
- 537
Is there an easy or well defined method of determining punching shear resistance for a point/line load on a slab on grade? I've ran these in SAFE before, and some of the load goes straight to the soil depending on its bearing/subgrade modulus. I'm wondering if theres a hand calc method that's accurate enough to get an idea of what's going on without having to set up a model. Of course I could just check punching assuming nothing below, but that would be overly conservative.
