We have 9" flat cast-in-place concrete slab with concrete columns. Because the parking garage in the first floor and the basement, the column spacing has to go 29' apart. According to ACI, the minimum slab thickness should be l/30, which is about 12", but client doesn't want to use that much thickness slab, how I we solve the problem without failed punching shear?
