Daparojo252
- Mar 25, 2015
- 13
I am looking for some help.
I have a internal tapered sleeve that needs to be pushed up a solid tapered shaft (similar to old propellor methods). I need to push it up by 1mm.
I am presuming that the thickness of the sleeve in the middle is 8mm, and the length is 115mm. The angle is 5.9 degrees inclusive. It will be steel/steel - no lubrication so the friction could be taken as 0.15
The Sleeve is 115mm Long, Taper Small End ID 64.50mm, Taper Large End 79.40mm.
What I am looking for is to calculate the axial force required to move it 1mm into position. Can anyone help?
