I'm investigating some joint failures in a 10" diameter, Sch 80, PVC pressure piping system. The pipe sections and fittings are joined by solvent cementing. This is a new installation and many leaks showed up during a pressure test. All the leaks are from cemented joints - from between the pipe and the fitting bell.
I'd like to rule out the possibility that this is caused by stress, so I'm wondering what the strength of a properly made cemented joint is relative to the pipe. What would the failure mode be assuming that the joints are properly made but the piping is overstressed from thermal expansion/contraction due to insufficient flexibility in the system.
The piping is ASTM D1785 and it is an above ground installation.
