Python scripting for inserting Cohesive seam in ABAQUS
HN150
I have been trying to add cohesive seam between two sections using python scripting.
After looking at the .rpy file I understood the process of adding the cohesive seam, creating the sets out of it and applying the section, as shown below:
Python:
p = mdb.models['PolygonsModel'].parts['Base']
s = p.edges
side1Edges = s.findAt(((0.205721, 0.058512, 0.0), ), ((0.204451, 0.063173,
    0.0), ), ((0.206197, 0.066779, 0.0), ), ((0.210843, 0.064586, 0.0), ), ((
    0.214843, 0.058891, 0.0), ), ((0.211022, 0.054718, 0.0), ), ((0.207876,
    0.055601, 0.0), ), ((0.206621, 0.05664, 0.0), ))
pickedEdges = regionToolset.Region(side1Edges=side1Edges)
p.insertElements(edges=pickedEdges)
#: Inserted 8 cohesive pore pressure elements by addition of 14 new nodes, of which 7 are midside nodes
e = p.elements
elements = e[2077:2085]
p.Set(elements=elements, name='CohesiveSeam-6-Elements')
f = p.elements
face3Elements = f[2077:2085]
p.Surface(face3Elements=face3Elements, name='CohesiveSeam-6-TopSurf')
f = p.elements
face1Elements = f[2077:2085]
p.Surface(face1Elements=face1Elements, name='CohesiveSeam-6-BottomSurf')
n = p.nodes
nodes = n[45:54]+n[2147:2154]
p.Set(nodes=nodes, name='CohesiveSeam-6-TopNodes')
n = p.nodes
p.Set(nodes=nodes, name='CohesiveSeam-6-BottomNodes')
n = p.nodes
nodes = n[51:53]+n[2154:2161]
p.Set(nodes=nodes, name='CohesiveSeam-6-MidNodes')
session.viewports['Viewport: 1'].partDisplay.setValues(sectionAssignments=ON,
    engineeringFeatures=ON, mesh=OFF)
session.viewports['Viewport: 1'].partDisplay.meshOptions.setValues(
    meshTechnique=OFF)
e = p.elements
region = regionToolset.Region(elements=elements)
p.SectionAssignment(region=region, sectionName='Section-MAT-ITZ', offset=0.0,
    offsetType=MIDDLE_SURFACE, offsetField='',
    thicknessAssignment=FROM_SECTION)
But while scripting, how do I get these element and node indexes to create set and then assign the section? Some times the number of elements inserted is not equal to the number of edges selected.
Can somebody help me to generalize this code or with some simple solutions?
