quadrant lines over 3D tube 1
tonyadbosal
Automotive
May 4, 2015
1
I draw 3D tubes, but for the bending proces I want to see on the outside of the tube, starting out of the quadrants of a circle, lines.
In 2D you can project a curve onto the tube, but does it also work in 3D and can it be done automaticly, because most of the time I receive the tubes in step
Try using the "isoparametric curve" command on the face(s) of the tube. This command can extract lines along the length of the tube.
www.nxjournaling.com
