I have spoken to several local electrical motor service centers, but none have been able to indicate an actual method of simply quantifying vibration in small motors (with the viewpoint of establishing if a given motor is unacceptably unbalanced).
In my particular case, a brand new 1.5hp 2 pole 3450 rpm motor (for driving woodworking machinery) appears to vibrate (under no load) much more than any similar motor I have ever encountered. A second new motor vibrates similar to the first, thus I am inclined to believe that the problem lies in all thier units. The problem appears to be a mechanical imbalance since the vibration diminishes slowly as motor winds down.
I would assume that an unbalanced motor under no load conditions, and suitably mounted would oscillate by a quantifiable displacement, possibly as measured by a dial indicator against the housing. Is there any such or similar method by which I can gage this vibration?
I wish to press the manufacturer for some sort of further solution but I would prefere to have some kind of hard data (rather than a vague complaint about vibration) to back up my claim. Any replies would be greatly appreciated.
