ih8xc
Geotechnical
- Jun 25, 2015
- 7
I'm looking for a method to quantify the sensitivity of a soil to changes in moisture content during compaction. Where I work a wide variety of soil types are used for bulk filling, but predominantly they are clean granular soils or they are silt to sandy silt tills. During the wet season we have problems reaching compaction with the silts due to high moisture and the inability to dry it out. Since most of our clients, and some of the contractors, are clueless when it comes to the environmental constraints of using these types of materials from borrow sites as bulk fill, I would like to be able to apply a moisture sensitivity value to our structural fill criteria. This way there is a very clearly defined requirement or warning with regards to the use of this material.
My initial thought was to determine the rate of change of the slope of the proctor curve. Basically, apply a 3rd order polynomial trendline to the data, derive to find slope, derive again to find rate of change of slope, and calculate a value at the optimum moisture content. Alternatively, I could determine the portion of the proctor curve above the compaction criteria (95 or 98%) and determine the moisture content range of that portion of the curve (say 9%, 6 below and 3 above optimum).
I'm wondering if there is a standard way of doing this, or if others have found an effective way to quantify the moisture sensitivity.
