Query in excel to combine cells with Superscript and subscript by UDF or Macro 4
raviprakash369
Aerospace
Mar 25, 2015
49
Hi all,
Again came with some query as I tried a lot and not able to get the result.
Question is there are 3 cells in excel with inputs like 20 in 1st cell, +0.2 in 2nd cell, -0.1 in third cell. we need a Macro or UDF to get output in a single cell with 20 and +0.2 as superscript, -0.1 as subscript.
I have tried the below formula which can combine the 3 cells and not resulting with superscript and subscript.
=TEXT(CONCATENATE(O24,IF(P24>0,"+"&P24,"-"&P24),IF(Q24>0,""&Q24,"-"&Q24)),"@") where P24,Q24 and O24 are display cell numbers.
If anyone knows please help.
Once again, you need declarations...
Code:
    Dim p1 As Integer, p2 As Integer
Skip,
[glasses]Just traded in my OLD subtlety...
for a NUance![tongue]
Ravi, there are all sorts of ways of implementing a concept. Your original question had noting to do with implementation. It was simply,
Ravi said:
Question is there are 3 cells in excel with inputs like 20 in 1st cell, +0.2 in 2nd cell, -0.1 in third cell. we need a Macro or UDF to get output in a single cell with 20 and +0.2 as superscript, -0.1 as subscript....where P24,Q24 and O24 are display cell numbers.
Then you posted...
Ravi said:
One more thing I found is : If value in any input cell is edited after running the macro, the result will be same as before. Associativity is not there after editing the input cells.
I replied...
SkipVought said:
You can "automatically" run this macro using the WorkSheet_Change Event.
Plz upload your workbook
Your feedback regarding how you need to use this macro has been virtually nonexistent.
Skip,
