  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Question about availability and reliability in complex system
Gintama
8
Dear all,
This is my first topic in your (our :)) forum. The matter is how to calculate availabily (A) in complex system.
I know that for a single components A=mtbf/(mtbf+mttr).
In some articles i've readed that:
for series of two components (just a simple example) Aseries= A1*A2 and for a redundant schemes Ared= 1-(1-A1)*(1-A1).
Is it correct all of this? This relations are mathematically correct for reliabilities but i've some problems to accept them for the availabilities, because there are already mean values.
I think that i should calculate firts the mtbf of serial or parallel and mttr of serial or paralle and than the availability as the definition.
Your approach is mathematically correct. However, a few examples show that the two approaches are generally comparable until Avail < 80%
TTFN
faq731-376
7ofakss
Thanks IRstuff for your reply.
I prefer to use a model mathematically correct but I'm reading, for my work , some documents in which there are calculations very approximate. For example there is mtbf of a complex system calculated as an mtbf equivalent (let me say) calculated, that is:
mtbf_eq= avail/(1-avail) * MTTR (where has been considered deterministic value)
The problem is: I'm finding often an MTBF equivalent that is greater than the minimum mtbf of a series. Can be possible ?
If I reduce the system to a RBD series of subsystems, I think that the system MTBF must be equal/lower than the minimum MTBF. It's right?
"system MTBF must be equal/lower than the minimum MTBF"
That's the way it should be.
TTFN
faq731-376
7ofakss
